OliverGräbner
Did you know about LABEL and HELPTEXT in *.dat files?
Did you know that you can use the keyword LABEL and HELPTEXT to set the label and the help text in the IFX Fastener Definition dialog?
Without LABEL and HELPTEXT you get this result for the ISO4014-5_6.dat:
Label: ISO4014-5_6 - this exactly the name of the *.dat file
Help text: n/a
Now we add LABEL and HELPTEXT to the ISO4014-5_6.dat:
LABEL ISO 4014 - 5.6
HELPTEXT Hexagon head screw with shank
Now we see this result:
It is also possible to translate the label and the help text using the <IFX loadpoint>\text\<LANG>\ifx_translation.txt
Note:
  • If you use LABEL and/or HELPTEXT in your *.dat file, then the translation from ifx_translation.txt is not used.
See also:
Did you know about ifx_translation.txt file?
Fastener Data Files
