dimension drag handles
  • April 25, 2013
  • 3 replies
  • 1972 views
Just switched to Creo 2.0.
How can I drag this dimension so it's directly under the arrowheads?
I can move the dimension in between the arrowheads but not below.
Would this happen to be a .dtl option?
We were able to do this in WF5.
Thanks.
Best answer by TomD.inPDX
I cannot see your image, Kevin.
Use the Shift key and then drag the dimension value to change the text position in relation to the leaders.
Thank you Antonius. The Shift key was it. Much appreciated.
Not sure why my image didn't show up though. I cut & pasted it from my Creo window & it was displayed when I posted.
Thanks again.
Kevin
You might try saving the picture to the computer and then use the camera icon to locate it.
This will upload the image to the PTC website.
