Dimension parameters in a table
I built a format with a table. I am using it to build a receiving inspection report. It work well for what I am doing but when go into "page setup" and replace the format the dimensions are removed as well. Can I set the table so the parameter values that I put in the table wont delete?
TIA
Terry
