Dimension trailing zeros not following rules for decimal places
  • July 29, 2013
  • 2 replies
  • 7155 views
CREO Parametric 2.0
My default decimal places for modeling is set to 2 but if the dimension is a whole number it displays as an whole number. If I edit the feature the dimension appears with 2 decimal places but unless I enter a dimension where the decimal places are non zero them the number always displays as an integer.
In any subsequent drawing of the part the dimensoins shown in the drawing reflect how they are shown in the model. If I look at the properties of a dimension in the drawing it is shown with 2 decimal places but they do not get shown on the drawing.
I have config options set as followis:
round_displayed_dim_values NO
round_prewf5_displayed_dim_val calculated
How can I display a dimension both in the model and in the drawing with the default 2 decimal places and then change this to the required number of decimal places on a per dimension basis as I could in WF3?
Best answer by ColinWriggleswo
Found problem due to system picking up wrong DTL file.
DTL file being used had lead_trail_zeros set to STD_DEFAULT instead of BOTH.
ColinWriggleswo1-VisitorAuthorAnswer
Thank you!!!
