Dimensioning question
  • March 2, 2010
  • 4 replies
  • 2656 views
Using the attached pdf as an example. How do I make a vertical dimension from a hole in the left view to a hole in the right view? Thanks
Go to View>Show and Erase and select 'axis' (you can sort by feature or view). This will place axis and centre marks on the part where relevant. You can then dimention from the axis of the bottom hole to the crosshair on the top hole (on the same view, left hand side). If you want to have a dimention attached to both views, you will just have to try it, I don't know what would happen, not sure if you can dimension from one view to another but at least you will be able to place the dimension you want.
March 2, 2010
If you needed a dimension from one view to another then the best way would be to dimension as Joesph says and pull one of the axis leaders over to the view with the dimension.
That was exactly what I needed. Thanks to the both of you.
