Disappearing Sketcher Dims
  • June 16, 2011
  • 0 replies
  • 378 views
Good morning,
I have had a strange problem in the last 2 days: When I open up Sketcher, it
all looks normal, but then, when I make a change, or add in a sketched
entity, all the dimensions and constraints disappear. The sketched entities
are still there. If I green button out into the part and RMB, Edit, all the
dimensions are visible and I can edit them in the normal way, it is just in
Sketcher mode they disappear. This does not always happen, only sometimes.
I am using WF2, M220, a Dell Precision 390 and a Quadro FX3500 with version
5.71.22.60.08 driver. As far as I am aware (unless IT sneaked in under cover
of darkness), none of this setup has changed recently.
Any ideas what I am doing wrong?
Cheers,
