Does someone have a function to count number of devices to generate a BOM quantity field?
  • June 12, 2012
  • 2854 views
I was informed that I need to write a java function to apply to a report field to be able to count devices for a BOM. Does someone have it to share?
I thought this resource should be available, has it is basic to generate a BOM and it is present is every schematic software I know.
This is very much available. I do not have Proe open now. As I recollect. Select the repeat region-->Attributes --> Recursive --> no repeats.
and then min repeats --> -1 [to prevent blank rows]
Hello Srinivasaniyer.
Thanks for the answer but this is not about ProE, but Creo Schematic, formerly RSD.
Could you help about it?
Sorry. I cant help you there. I don't use RSD / Schemetic.
