Draft versus something else.
The decision has been made to switch from a draft angle that was
previously specified to an linear dimension for the start and stop points
of the draft. If I am to continue to use shown dimensions which is our
practice here. I either need to replace the draft with a cut, or I need
to replace the driving angular dimension on the draft with linear
dimensions or reference to a datum plane controlled by a sketched curve,
which I cannot see how to do in the current version of Pro/E WF3 that we
have installed. Anyone have any ideas how to do this? Starting over
again would be a bad idea too, it would take longer and others have held
on to this change too long which is why it got dumped on me.
I guess the I could create a reference dimension in the sketched curve and
drive the value of the draft by that, but I am hoping to avoid that, as I
think it will cause problems for others in the future.
Thanks for any ideas you can lend,
Brian S. Lynn
Technical Coordinator, Product Engineering
Brian S. Lynn
