Drawing file size - how to reduce changing master representation to simlified one
  • February 9, 2019
  • 0 replies
  • 1003 views
Hello ,
In the 2D drawing a big assembly view was added as a master representation then file was saved  (let assume it saved file is 10MB due to TopLevel assembly size in Master represenatation).
Then the user delete all master representations (and releated viewvs) and replace them with a simplified one of the same model – so now CREO should generate smaller file due to it is refering to simplifed rep., but it doesn't - file size is now 14,2MB (as an example).
Is there any way to delete previous references to master rep. that the file size will be lighter or reduced?
Is there any tool in CRO4 thet it cleans the file automaticly or at list gives a chanse to see what is the reason of file size?
Thank you for a support
