Drawing format questions
I am working on new drawing formats and have a need to put some information in the format, but am having trouble. I would like to put a note on the format that list's the &format_name (not a real parameter that I know of) just like you would with &dwg_name or &model_name. If I put a note on with &dwg_name it shows me the correct information while I am modifying the format. However when I make a drawing bringing this format in, this line of text changes to the new drawing name. I basically understand why it is doing that but how do I list the format name on a drawing? Additionally if I can do that I would also like to list the PDMlink version of the format. Again I know the parameter is &PTC_WM_REVISION , but again it shows the revision of the drawing not of the format. In the end I would like to be able to look at a drawing in pdf or printed form and be able to check if the current format revision that is being used, I also would like this text to update if the format changes.
On another note - if you put a table in a format is there a way to fix its position so when you have a drawing with that format you are not able to move the table around?
Ron Rich
Senior Design Engineer
Extractors
TTI Floor Care North America
7005 Cochran Road
Glenwillow, Ohio 44139-4303
Tel (440)996-2477
Cell (440)591-9538
Ron Rich
Extractors
7005 Cochran Road
Tel (440)996-2477
Cell (440)591-9538
