Drawing program for BOM balloons
  • May 11, 2019
  • 1558 views
Hi!!
I have 2 sheets , one with master representation and the 2nd one is a simpler represntation i.e some parts are deleted from the 2nd sheet, otherwise everything else is same as the 1st sheet. But when i change the represntation from master rep to simple rep i end up losing the balloons as well.
Is it possible to use drawing program for somehow getting all the balloons from sheet 1 into sheet 2. I can edit the unwanted balloons later.
I don't think BOM Balloons from a Repeat Region are supported at all for views not in the Master Rep. Short answer, I don't think a Drawing Program is capable of doing what you want.
