drawing right click menu
  • June 16, 2017
  • 2 replies
  • 1741 views
In Creo 3.0 drawing mode, my right click menu only flashes when I try to access.  It flashes too quickly & will not allow me to select any options.  Is there any way to fix the issue without closing out completely?  What causes this to happen?
Thanks in advance
It might be getting hidden behind your current window if you have that window locked in front.  Press ctrl+alt+esc in your main creo window and see if that helps.
creed-41-VisitorAuthor
I use 2 monitors and had the drawings on one monitor & the assembly model on the other. I will try ctrl+alt+esc next time it happens.
