Drawing Text different on one computer
We are running Creo 9.0.5.0. I created drawing formats and templates in 9.0.9.0 and copied them to our other system. In the titleblock I have a surface finish symbol from the text library included with Creo. On my computers, it shows properly like this:
On one of my users, the surface finish symbol is a box.
What could be causing the font to be missing on one computer but not the other. We use a network install of Creo, so everyone is pointing to the same installation of Creo on each network. This is what makes it really confusing.
BenLoosliAnswer
To close this out, we found that the Symbol_Font setting in the older drawings needed to be updated to ASME from Legacy to get the surface symbol into the title block.
MikeBennett
Hi Ben,
Most of the time when a text symbol appears as a box, it means the font does not have that character defined or the font is missing.  With this text symbol, you should check the value of the detail option symbol_font between a correct appearance and an incorrect appearance drawing and system.  This specific symbol would be present for the symbol_font asme but not symbol_font legacy.
Just because you are using a network installation does not guarantee that this one computer or user doesn't have a personal or start-in config.pro overriding the install directory options.  You can check the File > Help > System Information's Configuration Information section to discover any unexpected config.pro files in that session.
The best guess is that there is a different template used with symbol_font legacy.
Mike
BenLoosli23-Emerald IIIAuthorAnswer
