Drawing views based on styles
Hello
Simplified Representations aren't all that simplified. If you have an assembly with a lot of patterned parts, you have to arduously include and exclude them manually, one by one.
And then when you make a drawing using those Simpreps, the BOM table changes.
Styles are an order of magnitude simpler to handle, and less confusing. Plus you can set if they should be shaded, transparent, wireframe or whatever.
I would very much prefer to assign a Style to a drawing view.
VladimirNAnswer
By the way, you can bring all your ideas here: https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
VladimirN24-Ruby IVAnswer
Right you are, I forgot that there is a separate place for this.
Thanks!
You're welcome.
