dual dimension gtol
  • May 14, 2019
  • 2401 views
I am creating position GTOL in a drawing and the dual dimension is not showing correctly. It is showing metric for both primary and secondary. All other dimensions show correctly with metric primary and imperial secondary.
https://www.ptc.com/en/support/article?n=CS267346
    • Add GTOL to part and then show annotation on drawing and it's correct
    • In Drawing, before placing, right click, select Destination and select the part rather than the drawing and place the GTOL and it's correct.
    • Config.pro option default_gtol_owned_by_model added in Creo 4.0 M050 onward may be used to specify the default Destination
      • When set to yes the default destination of a new GTOL created in a drawing is the top model of the drawing.
      • When set to no, the default value, the destination is the drawing unless the destination setting is changed during the initial definition of the GTOL.
  • Change in functionality starting from Creo Parametric 4.0 M070 and Creo Parametric 5.0.2.0.
    • Draft GTOL, when attached to dimension, will follow the units of the dimension it is attached to and not drawing units
    • For legacy drawings set drawing option update_drawing to 7565812 and update all drawing sheets
