DWG export of drawing in proe
  • July 26, 2011
  • 6 replies
  • 5426 views
While exporting dwg format from drawing, i am facing a problem that the linweight of section remains default and other lines got changed to the required lineweight after applying new line styles.
Is there any solution for this.
Our team is a facing a problem regarding drawing module in proe. The issue is related to line weight during exporting of drawing to dwg format.
In drawing i had made a line style named object with line weight 0.5, and applied to all views. In the section A-A the line weight is not shown or applied properly and during export to dwg, proper output is not obtained.It is mainly in the area of section that the line weight is not proper.
In Pro/E convert the view that causes the problem to draft entities and then apply your thinkness to each line segment.
My advice is not to bother with line thicknesses in proe or autocad drawing at all.
I have to complete a big project of 500 drawings, most are in a1 and a2. how i can apply lineweight after conversion , the project is time bound one.
Is there any other options. I think u had studied the attachments. Is there any fault in my method of aproach?
