.dwg of half a component/assembly
  • February 27, 2018
  • 6 replies
  • 2951 views
Hello!
I'm wondering if it's possible to get a drawing file of just the front portion of my assembly?
Yes, it is possible. But you are going to have to provide more specifics if you want people to provide suggestions to point you in the right direction.
dmojay1-VisitorAuthor
Yes, of course. I have made an assembly of a fuselage and I want to make a .dwg of the cockpit. I made the fuselage all in one go and I don't know how to separate the front portion from the back portion.
StephenW
You mean like a cross section in a drawing (.dwg is the autocad extension for drawings, .drw is the Creo extension for drawing)?
Or do you mean make separate parts of the front and the rear of the fuselage?
