DXF-import non-native CREO extrude -- impossible to work with
- 7 replies
- 772 views
- Translate All
I have imported a DXF file in CREO and thus created an extrude out of this DXF file, using the PROJECT function.
To distinguish this from a regular CREO extrude, I will call this non-native CREO extrude a DXF-import extrude (for lack of a better name).
If it already has a name I will stand corrected.
Anyway, this DXF-import extrude is impossible to work with.
I am trying to make it accept a different color than the background, but it does not work with regular means -- this DXF-import extrude seems to be a surface that CREO cannot handle like any other extrude generated directly in CREO without an external import.
Is there a way to make this DXF-import extrude behave?
Maybe create another native CREO generated surface, identical with the DXF-import one and transparently on top of said DXF-import extrude, that would be more amenable to work with?
I have attached the PNG file (source for DXF), the DXF file, the part file with the DXF-import extrude and two screen shots of how it looks and how it should look.
Many thanks!
