easy way to create part drawings from part in assembly
  • June 27, 2013
  • 2 replies
  • 974 views
I've an assembly with a few parts in it. Can I make easily the part-drawings (with templates) of all the parts all at once?
Does there maybe exist a UDF for?
Thx!
it is no exist but you can create your custom html file and use Pro/Web.Link for Creo Parametric - in your installation folder you can find User's Guide:
installation _path\Creo 2.0\Common Files\datacode\weblink\weblinkug.pdf
and weblinkexamples:
installation _path\Creo 2.0\Common Files\datacode\weblink\weblinkexamples\html\pfcDrawingExamples.html
Vladimir
Nothing automatic, but you can do this manually.
