Ecad....
  • January 20, 2011
  • 4 replies
  • 4443 views
What are users using in the field to do circuit board design. We are currently using PADs by mentor graphics. I want to know what program works best with pro/e and windchill.
We currently use PADS with WF4 quite sucessfully. We swap data between the two systems in both directions.
My only complaint is that Silk Screen and copper layers don't import into Pro/E (Sorry I refuse to call it Creo Elements Pro..... daft name !! ).
It would be very useful to have both those layers as it will help with board orientation and we could use the copper in our CFD analysis.
We have no experience of Windchill at all.
Have you done any testing with WF5 yet? We seem to have found an issue. You can no longer import pin holes.
Not yet , we use a CFD program and I can't upgrade until its compatible with WF5.
That seems like a major problem , what have Mentor said about it ?
