ECAD_HINT.MAP USAGE FROM WINDCHILL
Hello Experts,
Greetings. I had a question for folks using the ecad_hint.map file directly from Windchill VS getting it from a network/local directory.
Have you run into any issues doing this, a quick test I ran revealed that it takes a little longer from Windchill VS the other method and more log errors are written into the ecad log file from Windchill VS the other method.
Any feedback is really appreciated,
Thanks in advance,
Anil
