Error message
  • November 8, 2011
  • 3 replies
  • 1035 views
Hi all need some help here.
I have an assembly and every time I open the model I get this error (see doc)
Can anyone help me resolve this issue as I can't find where the error is
cheers
Colin Down
Design Engineer
Colin Down,
We need more information here.
It looks like you are missing some components in your check-out process.
That's "assuming" that you have IntraLink or Windchill. It's not good to
assume.
Michael P. Locascio
Start by opening the assembly in question and then looking for the
feature it says is missing. It may simply be suppressed and resuming it
may correct the problem. If you can't find it, then look for the
features that say they have missing reference and redefine them and
correct the missing ref.
Finding the features might be the hard part, but you can use the find
tool to search by feature id and make that easier.
Doug Schaefer
I don't have an answer. But I am pretty sure its pattern related.
