Explanations
  • April 11, 2017
  • 8 replies
  • 3934 views
Morning All
Can anybody help me  or direct me to a resource for some of Creo's error messages? My current favourite is:
The boundary of the highlighted surfaces was extended. Unexpected results are possible.
I get this after merging two quilts yet when I search for single sided edges the quilts show gaps!
hi,
These error messages are mostly just recommendations, they can hardly describe what to do with the actual geometry. Do you mind attaching the model to a reply and specifying your version of Creo Parametric or Pro/E?
DieselPig1-VisitorAuthor
Hi James
After much fiddling and exploring the forum I have fixed the problem!
I changed the part accuracy to absolute and a value of 0.15, this is OK as the part is a large casting and does not require micron accuracy.
The accuracy was left as standard and was too fine. I just wish the cryptic messages were a little more helpful and PTC supplied a ready reckoner with useful pointers to fix the problems!
These forums are the best resource I've found.
hi Phil,
Ok, great, I guess you work on models with surfaces that are of organic or let's just say non-analytic shape. That's a pretty coarse accuracy you have there I'd say, even in millimeters.  Too high or too low accuracy (depends on how you look at it) usually leads to a lot of trouble with these compound surfaces when the data have to be used in different CAD/CAM/CAE system afterwards. Think of a simple surface, like a cylinder, cone or even a sphere, analytic shapes like these can be converted to other CADs easily cause the other CAD can figure out the topology of the surface even when the accuracy is bad. Not so often with spherical shapes, but cylindrical and conical shapes transfer really well. The real trouble comes with models that have multiple supposedly merged non-analytic surfaces, in cases like these the resulting import to another CAD system happens to be with alot of gaps or even bad surfaces that need to be completely replaced. Such models require alot of effort to be fixed and solidified, effort which brings in no additional value. That's why setting up accuracy to this high number is usually not recommended.
