Explode sub-assembly into top-level assembly
Dear Community,
After creating exploded states in the sub-assemblies, I would like these states to be automatically active when exploding the top-level assembly. I mean, the sub-assemblies shall explode when the top-level assembly explodes.
How can I get that?
Thanks in advance!
Stefano Cristofanelli
Chris3
Chris3Answer
Using the Default explode allows you to propagate it into the next higher assembly (start with the default explode in the next higher assembly). There was an idea for making this happen with other explodes but it was "archived" which likely means it won't be coming anytime soon.
https://community.ptc.com/t5/Creo-Parametric-Ideas/Subassembly-Explode-States-propagate-to-higher-levels/idi-p/470472
Chris3
Chris321-Topaz IAnswer
Steto13-AquamarineAuthor
Dear Chris3 Pearl,
thank you very much for your reply. Finally, how can I save a custom exploded state as Default Explode? I tried, but I did not find out the way.
Best regards
Chris3
Maybe some else knows of a trick but I am not aware of a way to do that.
