2-Explorer
October 9, 2018
Exploded Lines break constantly in Assy
  • October 9, 2018
  • 9 replies
  • 5088 views
constantly get failed explode lines in the assembly models.  obviously outdated components or whatever the reason, but the only thing to do is delete, and redo the lines.  is there something i am missing here?
Patriot_1776
No, they just s#ck.  What I do is make the lines as a sketch in my dwg using references (to force parallel, etc.).  I find that's easier and more robust.
dgrobe2-ExplorerAuthor
2-Explorer
October 11, 2018
we used to do it that way, then started with the explode lines, i guess we should just go back to the old way, thanks for your insight.
Mahesh_Sharma
22-Sapphire I
October 16, 2018
@dgrobe
You may vote existing Idea Explode lines editing in an explode state; Re-establish a new reference about the same issue.
 What about creating an Explode Line Sketch?
buyessay
Patriot_1776
You mean in modeling mode?  That's an interesting idea, but if you change the iso angles it'll all get FUBAR'd.  the sketch at the dwg level may be more robust because it
s 2d, but I haven't proven this.
Me, I don't like using explode lines anyway, it just clutters the dwg up IMO.  If I get the choice, I just show exploded views without the lines.
