Export Parasolid tips.
  • March 21, 2018
  • 21 replies
  • 9410 views
Having real issues with the the export of parasolids in creo4. When reading back in they are really chunky,with surfaces missing. Anyone got any tips. Parts are set to default tolerance in mmns.
SC.
if you export models from Creo 4.0 and import them back into Creo 4.0, then test all available export formats.
Genero1-VisitorAuthor
HI.
I have been doing that for the last day or so. I was wondering if anyone had any pre set up configs to aid the export. It looks like a tolerance issue. The models on import are really bad.
SC
if you provide some model and describe the problem using text and pictures, then I hope somebody will help you.
2-Explorer
March 22, 2018
Hello @Genero
 in my opinion export OUT of Creo can be correct, but error can be during import back to Creo. Try to turn off temlates during import or change accuracy for import...
As u sad, try to focus on accuracy. Its the first going on my mind...
Regards
@mbonka
Hi.
I have had a play with that without much success....I will have another play.
I've had occasion where the settings file is in the working directory and it takes them on without even knowing it.
Parasolid (X_T) is my secondary export format.  Never had one go "chunky".  Some limited missing surfaces is normal for complex shapes.  Import data doctor can help with these if it is important.
