Export step file with annotations but without quilts
We would like to be able to export a step file with annotations but without quilts.
Currently when selecting annotations, quilts are automatically selected and greyed out so they cannot be unselected.
A PTC support representative already explained there's no way around it using the standard options.
Please make it possible to export a step file with annotations but without quilts (product idea).
Currently when we want to send a step file to our vendors (mold maker for example) it includes confusing quilts which are a potential source for errors.
Mahesh_Sharma
22-Sapphire I
@peyckmans When selecting Annotations Quilts will and grayed out, this is as per limitation of application.
I don't know how far this will help, but, did you get a chance to try exporting data where quilts are in layer and on  exporting to STEP exclude the contents of that layer?
peyckmans1-VisitorAuthor
Hi @Mahesh_Sharma, thanks for your reply.
I indeed tried excluding the quilts by customizing the layers in the Customize Export option and it worked.
But this workaround can, as far as I know, only be applied when exporting Step files manually.
We are trying to exclude quilts from Step files that are created by a conversion server (Cad worker) and therefore need to be able to accomplish this through configuration options/files.
The Layer status in the Customize Export option can be exported to a text file and can be imported on a next (manual) occasion but I didn't find an option to automatically apply it.
Any idea?
3-Newcomer
Another possibility as ocorten-2 in https://community.ptc.com/t5/3D-Part-Assembly-Design/Export-only-visible-parts-from-an-assembly/m-p/719762#M118971 already wrote and we also use is:
You can Enable the Annotations and Disable the Hidden Entities by using an export profile.
Then edit the .dep_step profile file and set the Hidden Enitites to zero:
            <profile_options_xar__ENTRY id_="Hidden entities" pointer="TRUE">
                <value___PO__b__PC__>0</value___PO__b__PC__>
