Export the cross section from Creo Model
  • January 12, 2015
  • 2 replies
  • 3799 views
I am trying to export the model with clip section view, for example there is offset cross section A in the Creo Model, I would like to export the solid model in that state. now its exporting as IGES or STEP without section
You will need to actually create the cross section as a feature, ie extrude and remove material. (You could possibly do is as an instance or just suppress the feature when finished).
Adam is right. Cross sections are states; not geometric.
You can extrude cut in both part and assembly modes for solid models... and trim surface models.
I use this method a lot for shaded cross sections in drawings which Creo does not support. I create a next level assembly and section this for the sole purpose of a shaded cross section in a drawing.
