Export to DWG - ACAD14 - Wildfire5-M020 - "DWG file creation failed."
  • March 25, 2010
  • 0 replies
  • 451 views
Hello Pro/Users,
Before placing a call with PTC support I want to see maybe I can get my
fix from this great forum.
Problem:
When Pro/E drawing is saved or exported as a DWG file in AutoCAD14 the
save operation does not succeed and an error message appears.
We noticed that this happens when the drawing contains BOM balloons.
Error Message:
Temporary solution:
We save in Autocad2000 and the export is successful.
Permanent fix (we really need the AutoCAD14 format since a lot of our
vendors are requiring it):
Any thoughts, fixes?
Thank you in advance!
