Dale_Rosema
Exporting a step file but also getting all the hidden trim surfaces
While exporting some step files and then importing them, all the extra trim surface that are hidden are coming along with the part. This doesn't work when you are trying to render some parts. Is there a way to have these extra surface remove during the creation of a step file?
Dale_Rosema
When exporting a .stp file. Click on the Options button
Then uncheck the quilts and hidden entities
If I save profile, it want to add "def_profile.dep_step"
Where is this file normally located.
This does remove all the extra surface.
Mahesh_Sharma
22-Sapphire I
@Dale_Rosema
I think Tom's reply to this post will help you.
Dale_Rosema
Dale_Rosema23-Emerald IVAuthorAnswer
Mahesh_Sharma
22-Sapphire I
You can save that to any location and set export_profiles_step to read profiles from that directory.
