Exporting Annotations to .STP Format
  • August 15, 2014
  • 2 replies
  • 2579 views
I've been attempting to save my models in the STEP format with annotation features and have been running into some troubles. I have changed my step_config.pro include annotations (i've tried both ap214_is and ap203_e2) and toggeled the annotations block to include them. When reopening the created .stp file in Creo it seems I've lost the annotation. I see an annotation titled STEP_COMMENTS in my model tree after opening the file, but the text is 'NOT SPECIFIED' instead of the annotation I had created.
Has anyone had similar troubles that they've resolved?
Sean
Welcome to the forum, Sean.
I have successfully exported annotaiton to 3D PDF... but never tried with STEP. I will see what I can do this that.
What version are you running?
From Creo 2 it worked. The option is a simple checkbox in the export dialog.
It did fail to pick up the note annotation that was "flat to screen" however.
I exported a series of dimensions and an attached note.
It imported as a separate annotation element.
Each annotation element is is converted to a symbol.
