Exporting DRW to DWG
  • February 2, 2012
  • 989 views
Pro Gurus,
I need to export a multi-sheet Pro/E drawing, DRW, to AutoCAD, DWG. I've not done this before and need some guidance. There's paper space and model space options. Both produce an off white sheet with yellow text, dims and balloons. That is very difficult to read. I also tried exporting to DXF and got the same result.
WF 4 M180
Win 7 64 bit
Any advice would be greatly appreciated!
Bill Watkins
Sandia National Laboratories
Albuquerque, NM
505-845-9666
You need to copy the attached file into your current working directory. This is just a text file and can easily be modified. It will create all black lines on a white background upon import into ACAD.
If the attached file doesn't come through, here's the text version. Just name the file "dxf_export.pro" and you'll be good to go.
map_color DIMMED_COLOR 7
map_color LETTER_COLOR 7
map_color HIGHLIGHT_COLOR 7
map_color EDGE_HIGHLIGHT_COLOR 7
map_color GEOMETRY_COLOR 7
map_color HIDDEN_COLOR 7
map_color SHEETMETAL_COLOR 7
map_color CURVE_COLOR 7
map_color SECTION_COLOR 7
map_color DXF_TABLE 7
map_color DXF_BALLON 7
map_color DXF_FORMAT
Bob Schwerdlin
Design Engineer,
Dukane Corp.
2900 Dukane Dr.
St. Charles, IL 60174
630-797-4974 direct
