exporting files containing ellipses from pro/engineer into iges or dwg(ACAD) files, the ellipse is seen as many small lines, how do you export it so that it will see it as an ellipse.
  • May 4, 2012
  • 2 replies
  • 1491 views
After choosing the type and name of the file, in the export window (i.e. "Export Environment for IGES") -> "Entities" tab, did you try to check the option Splines "As Splines" instead of "As Polylines" ?
I'm not sure it still exists in Creo as I'm using WF5.
try the following config:
intf2d_out_enhanced_ents spline_and_hatch
