Exporting the x,y,z position of a point to Excel
  • May 28, 2014
  • 3 replies
  • 1730 views
Hello ,
I am trying to export the (x,y,z) position of a point associated to one of the solids present in my assembly whith respect to the default coordinate system.
it is known that I can export dimensions and parameters using excel analysis, but how can I export the (x,y,z) coordinates.
Thanks for your help PTC community !!
Try an iges export. This should list all points with X,Y, and Z coordinates within the file.
If you measure the transform from the default, that produces a file with the XYZ in it.
If you need it more automated, you could write a tiny script in Pro/Web.Link to push it over.
2-Explorer
August 18, 2014
Hello Nicola,
have the posts from Antonius and Christopher answered your question and helped you solve your task?
It is always nice to get feedback. Also making use of the Correct Answer / Helpful Answer is a good way to mark a thread as answered and highlight relevant answers for others.
Gunter
