Express 4.0 locking up when generating 2D drawings
  • January 2, 2013
  • 3 replies
  • 1389 views
Hi All, Happy New Year!
I am using Creo Elements direct Modelling Express 4.0 but am unable to generate 2d drawings from a model, even when following the quickstart project with the relevent quickstart example file - whenever I attempt to 'update all views' the program just locks up. I have the same problem with a model I've created.
Is there anyone out there that can help?
Ian
Best answer by TomD.inPDX
This sounds like a platform issue. You might try changing your graphics settings or updating your graphics drivers (or even downgrading). I am not familiar with the Express 4.0 options, but if you can change the OpenGL settings to something else, it might help too.
I have used Express 4.0 for quite a few import projects and created some drawings. I have not had issues on several platforms.
A last resort may be to reload the software, but that really shhouldn't affect anything unless there is an install error.
Hi Antonius
I reloaded the software which made no difference.
I downloaded the sw onto a different machine and - it works no problem.
So I reduced the hardware acceleration on the original machine and that solved it!
For anyone else with a similar laptop, mine is a dell vostro 1500.
Many thanks for your help!
Ian
Glad you are up and running. Enjoy
