external merge in sheetmetal mode
  • July 1, 2010
  • 0 replies
  • 462 views
More of a statement than a question, but I was looking to add an external merge geometry to a part that would ultimately end up in sheet metal mode. If I convert the part to sheet metal mode first, then I only have the option to add the geometry as an inheritance. The merge/ inheritance toggle button is grayed out.
If I add the external merge in standard mode, I have both options (merge or inheritance). I can select merge and then convert the part to sheet metal mode.
WF3.0
Just wondering if anyone has seen or know why this works this way.
Patrick Fariello
