extract material properties
  • February 24, 2016
  • 5 replies
  • 2930 views
Best answer by sr-4
Hi
Thank you so much . It is working Perfectly 100%
Thanks a lot
Srini
you can:
  • create auxiliary drawing containing with your assembly set as drawing model
  • create table with repeat region in the drawing
  • 1st column ... &asm.mbr.name
  • 2nd column ... &asm.mbr.ptc_material.PTC_MATERIAL_NAME
  • select the table and save it as csv file
  • change csv file name extension to txt
  • open txt file in Excel and save it as xls file
MH
sr-41-VisitorAuthor
Hi Martin
Thank you so much for your Reply.
I am really looking to generate an text file or CSV file from  Creo  without going into the drawing information.
Say  I have 20 parts in my active window under one assembly with the tree window on left side.
I am looking a script or procedure to generate a txt or csv file t have part number in forst colum and material properties in the second coulmn.
The reason I am asking this question is used use for my simulation using external solvers.
Thank you
you can also configure Model Tree to show PTC_MATERIAL_NAME parameter in its column and use Save Model Tree command.
MH
