Extrude attached or unattached option
  • January 9, 2018
  • 5 replies
  • 5247 views
In Extrude command, There is this option, attached or unattached, I didn't found any utility for this. What's it intend?
2-Explorer
January 9, 2018
In sheet metal?
http://support.ptc.com/help/creo/creo_pma/usascii/#page/sheetmetal%2Fsheetmetaldesign%2FYour_Design%2FAbout_Creating_Walls.html
A wall is any section of sheet metal material in your design. You can create two kinds of wall:
• Unattached wall—An independent wall that does not need another wall to exist.
• Attached wall—Dependent on, at least one other wall.
You can create these types of unattached wall:
• Planar
• Extrude
• Revolve
• Boundary Blend
• Swept Blend
• Sweep
• Helical Sweep
• Blend
You can create these types of attached wall:
• Flat
• Flange
• Twist
Mahesh_Sharma
22-Sapphire I
January 9, 2018
Those are state of geometry preview within the feature creation user-interface.
Attached—Displays the geometry as it appears when you finalize the feature.
Unattached—Displays the outline of the geometry you are defining.
Config option 'dynamic_preview' controls the default preview state.
For better display, Create a solid box and on that create a hole. When creating hole use Attached or Unattached.
CAD_user14-AlexandriteAuthor
So, it works only for the preview option
Mahesh_Sharma
22-Sapphire I
January 9, 2018
yes.
