Family Table Regeneration
Is there a way to only regenerate the entire family table with my command? I'm modifying a part with family table, and each modification causes the entire family table to be regenerated.
luiz.hnmAnswer
I found the answer in this post: https://community.ptc.com/t5/3D-Part-Assembly-Design/Suspend-family-table-verification-temporarily/td-p/801680
All i need to do is not have all instances in session.
if you modify generic then it is necessary to verify all instances before you save generic.
luiz.hnm12-AmethystAuthor
Thanks for answer
Yes, but I'm talking about the fact that in the moment that i apply a feature, like an extrude cut, Creo starts to regenerate the entire family. But i would like to make all the modifications first, then i want to manually go to the family table window and regenerate, because the family table is big and there is no reason to regenerate it many times.
  1. How do you know the entire table is regenerated? Are you looking at the Verify window and seeing that all instaces are verified?
  2. Are you working in the generic or in an instance?
