Family Table Settings - PDM Link
WF 4.0 M060
PDM Link 9.0 M010
We introduced PDM Link about a year ago. During this implentation, we brought in several family tables of common hardware components. We have been running into a major problem. The problem is that when we need to revise an instance of the family table, we are required to check out and revise all instances of the family table. For instance we havepin type component and a diameter tolerance needs to be changed for one size. This currently requires all instances to be revised and checked out.We are looking into possibly putting tolerances into the family table itself as well as looking through the config.pro options to see if there is something in there that we can change. I am assuming others have this pain out there? Any clues?
A suggestion was to set this create_drawing_dims_only" to Yes, but that will tie our hands.
James
