3-Newcomer
February 25, 2015
Family Table shown on Drawing - Controlling instance range in columns
  • February 25, 2015
  • 624 views
I have a table created on a drawing that has repeat regions to populate info from a family table. It is two columns wide and 24 rows tall... I need to add more rows/instancesto the table, however, unless I change the text size and row sizes, which I don't want to do, the table is going to be too tall for my print. Is there anyway to add two more columns to the table and have the added instances/rows I need to add show up there? I wasn't sure if you can set itup so the repeat region would only show instaces 1 thru 24 in one set of columns and have 25 thru 30 show up in the next colmns? Or create another table next to it that only shows those instances? Wasn't sure if I had any options here...
Thanks!
Ted
You want to paginate the repeat region. See the attached email.
David Haigh
