Family Tables
  • January 20, 2010
  • 2083 views
Hello all; I have recently discovered Family tables, and I have a general question on its capabilities. From what I can tell, it is very simple to be in a top level assembly, and add different components in the columns of a family table to chose whether or not to display them in certain instances. My question is; Say I have a part that has three different instances, say a bolt that has three different lengths. Is it possible to be in a top level assembly, and not only chose whether or not to display the bolt, but chose which instance of the bolt I want? If family tables can not support this feature, is there a feature within Pro/E that can help me with this? I use WF 4.0 Thanks!
Yes. Just put the instance name in the column.
PhilipRoy1-VisitorAuthor
How exactly do I do this, I have not been using family tables for very long.
I'm trying to recall from memory since I don't have an assy with instances in it in my current workspace. When the instance name is in the column, you can highlight the cell where you want to change the part instance out in, go to tools (top menu in the family table), and it should allow the option to swap out that instance with any instance from the part family table.
