Feature cut advanced
I have a solid model wich is getting quite complex geometry.
I would like to make an extrude boss into the main body and then cut only the extruded feature.
In SolidWorks there was an option to not merge the bodies.
That technique was quite good in some cases.
You could keep the extrude boss as a seperate body, make some cuts and after that merge it to the main model.
As I see there is no way to avoid merging featrures from main body in Creo.
Is there any other useful technique to do this?
Is there a way to cut a feature without cutting the entire model?
