Feature Simplified Representation in Part
- We have created Family table also added feature base simplified representation
- Created instances
- Created drawing (DRW) file of generic model and added master view and also added simplified representaed views in the generic drawings.
- Replace the same generic drawing for instance drawing and save the same with master view and simplified representation views.
- In that senario in Instance only master view dimensions updated as per instancesand simplified representation views not updated as per instance dimensions. All are same as per the generic only.
- Raised the issue to Tech support but there is no solution for Featurebase simplified representation.
BUT
- I have got the idia and did
- I went in instance drawing simplified representation view info. and edit the "View Model Number " given instance number and the same view updated as per instance dimensions.
Goraksha
9823447572
