Fill Pattern doesn't work as needed
- February 1, 2013
- 4 replies
- 2250 views
I want to make fill pattern on a complex surface, I can do this on every single surface but the result is not that I needed... that is, there were mismatches on the borders... so I copied the surfaces into a single quilt and intended to make a pattern on it. But the droplist where I can select the option "Map to Surface UV Space" is dimmed... Here is the picture:
