Filter Repeat Region in Drawing
  • February 18, 2015
  • 1432 views
Hi ,
I have a repeat region that is recursive / no duplicates. So it includes every part in the model and totals how many of each part is used. I have tried to set up a filter by rule but it does not seem to exclude the data that I wanted to exclude. I have a parameter named Part_Desc that includes the description of the part. There are some parts that are used to make an assembly and we purchase the assembly from an OEM. The sub parts for those assemblies do not have a value for the Part_Desc. I wanted to be able to exclude any of those items from the repeat region. Any help or suggestions are greatly appreciated. Thanks, Jon
We create a parameter called "BOM_FILTER" set value to "YES" in components that we want filtered from our repeat regions.
Our filter rule looks like this.
&asm.mbr.bom_filter != YES
&asm.mbr.cparam.bom_filter != YES
Use whatever parameter name works for you, The key here is the "!= YES" not equal, your other components won't have this parameter so they should display just fine.
