Format parameters inherited into drawing?
We upgraded from WF2 to Creo1. In WF2 we had created formats with many parameters and as the drawings were created the drawing file inherited the parameters and values. Using WF2 we could run ModelCHECK against the drawing for these parameters. Since the move to Creo1 created drawings use the same formats however the parameters do not move into the drawing (as a new one is created) and we are prompted for values redundantly for those used in multple locations (the past was one answer). After drawing create in Creo ModelCHECK indicates all parameters are missing.
Does any one know how to return this inherited behavior back to the drawing file?
