GD&T dual dimensioning
  • October 8, 2013
  • 2 replies
  • 1899 views
Hi all,
Is there possibility to turn off dual dimension for GD&T....
I need it only for dimensions .
Best answer by TomD.inPDX
Welcome to the forum, senthil.
You probably cannot do this with any default settings. All dimensions are treated equally.
However, if you don't need to create the GD&T blocks within the model as GTOLs, you can always create them manually with a note. There are only a few options that are more challenging than most.
I am curious to understand why you wouldn't want the tolerance value to be dual dimensioned?
NSS14-AlexandriteAuthor
Thanks for your quick reply. I exactly did as what you told.
Machine operators confuse with the primary units(they are familiar with secondary units), thought to introduce secondary units.
For GD&T, I thought it won't be confuse as such and like to turn off dual dimension. That's the reason
