Geometry check present when creating a round feature
- 6 replies
- 3516 views
- Translate All
I have a round feature that is throwing a geometry check when modeling the same underlying geometry created differently. The round appears to be there and accurate visually.
I am looking for an explanation of the root cause of this error. This is a simplification of a much more complex model that includes the same geometry. The production model uses a mirror part geometry as only half the part is explicitly modeled. This is the only geom check in the model and I have not been able to get rid of it. I have tried datum reference surfaces for the mirrored boss but that did not resolve the error. Does anyone have any insight into why this error is generated?
1) Both models (Creo 4) use the same absolute accuracy and are included here for reference
2) Both models share geometry that is congruent
3) Only the model that mirrors the 180 degree revolve feature throws the error (mirr_part_geom_check.prt)
The error is:
Set cannot be constructed on the highlighted pair of surfaces.
Recommended actions:
Try to create feature as "Unattached", and complete it using quilts.
