GPU Driver crash
  • October 13, 2015
  • 3 replies
  • 2258 views
I'm a formula SAE team member, and i have just installed PTC Creo 3.0.
My PC has:
CPU:      i7 4970k
MB:       Asus maximus VII Hero
GPU:     Shappire ATI HD 4890
RAM:     Gskil 8gb 2400mhz
HD:        SSD Samsung 850 pro
The problem is that when i'm opening last year car assembly, or a part. A few seonds later, Creo freeze, black screen and than "Display driver AMD has stopped responding and has recovered".
Obviosly i checked for update but nothing found.
Thank you,
Francesco Ricchieri
Francesco,
Try turning off some of the newer OpenGL features, and see if that helps.  In your config.pro file, set the following:
enable_opengl_fbo no
enable_opengl_vbo no
enable_opengl_shader no
Dan N.
config.pro in wich folder?
Anyway do you suggest to change graphic card? It's obsolete?
Thank you
2-Explorer
October 13, 2015
<LOAD POINT>\Creo3.0\MXXX\CommonFiles\text\config.pro. Add the options using a text editor, one per line as shown by Dan.
